You should show only about 200 psi above what the regulated pressure is when you are not turning the steering wheel. That would be the differential pressure behind the flow divider valve added to the pressure of the regulated circuit. The reading you are getting down on the bottom plug is regulated pressure and should remain close to the same at all speeds. Sounds like you have a restriction but your steer to stop pressure sounds good. Steer to stop is controlled by power steering relief valve, regulated pressure is controlled by regulating valve and is the return oil from power steering so the steering pressure will always have to read regulated pressure plus the differential pressure build up behind flow divider.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
