Nothing magical about it. If you were to double the amps(which you don't) you would need bigger cables yet.Voltage is determined by the # of cells in the battery. Amps are from the size and # of plates. A 12 volt of the same size as a 6 can't double the amps cause there are only half as many plates( more or less ) to a cell. It is the voltage that causes the starter to spin. Loose a couple volts & the starter slows down even if the amps are there.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
