I would try cleaning the connections at the ignition switch & solenoid on top of the starter, after making sure the battery cable ends are shiny bright also. Any corrosion robs a 6 volt system of much needed amperage. High quality copper battery cables double ought in size usually help a lot, a welder friend of mine offered me some of his discarded cable he had lying around & it works great. I soldered new terminal ends on them both.
The larger cables offer less resistance. Any wire you need to replace, go with 10 ga copper, less problems down the road.
I would go with the highest cranking amp 6 volt you can find, the heavier the battery the better, this means the lead plates inside are either bigger, or there is more of them.
The best ( and most expensive) I have found, BUT at least you never have to worry about rust in the battery box again :
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
