Re: 400 won't start without battery charger
Posted by Leroy on July 26, 2012 at 06:05:57 from (69.88.205.38):
In Reply to: 400 won't start without battery charger posted by Evan From IA on July 25, 2012 at 12:40:58:
I am no mechanick but the key here is when you have the battery charger hooked up where are the charger leads hooked to? Are they hooked to the battery cables at the post or elseware? If hooked at the post then your wireing is OK or the charger curent would not go thru either and that the battery is either not making contact with the clamp or the battery is bad. Now if you are hooking to someplace other than the battery ends on the cables then you have a wire problem. To check for that hook the ground to battery and try using the spot where you are getting it to start, then do the same proceduar with the positive post and it will tell you if you have a positive wire problem or a ground problem. Charger hooked directly to starterand not using starter button does it crank better and if battery ignition will it start that way, a week battery would provide enough power for just the points but not starter and points.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
