If I simply take the wire from the GEN terminal on the regulator, and move it over to the BAT terminal on the regulator, will that effectively bypass the regulator?
YES that by passes the Cutout Relay portion of the Voltage Regulator (its between BAT and GEN). If you do that the hot ungrounded battery feed via the ammeter which is present on the BAT terminal, is then connected to whatever you then connect that terminal to, such as say the output of an alternator...........
DONT FORGET MOST ALTERNATORS ARE FOR NEG GROUND so if the tractor were at Pos Ground??? you would have to swap ammeter leads or it will register bass ackwards
If a tractor has a coil ignition and you changed polarity, the coil leads would also need swapped HOWEVER if youre already at neg ground (like on most 12 volt tractors) neither of the above swaps are necessary
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
