Posted by Dan Osborne on July 31, 2012 at 10:23:06 from (98.20.50.193):
Decided to mess with this again. Posted back in march and got varying answers. I bought this tractor from a gentleman that said he quit using it because it just became such a bear to get started even after he replaced the glow plugs. Found on a Red Power forum that engine won't run if return line is pluged. Remove line from pump, and sure enough, I could not blow through line. Thought I found the problem. So I put a hose barb on pump and ran a line into a bucket. Still won't run. I pulled all glow plugs and when cranking engine over, I get diesel vapor and air out of glow plug holes. However, when glow plugs are in, I do not get white smoke out of exhaust. I have a good running 560 diesel to compare it to, and when it cranks over before starting, I get white smoke out the exhaust. Where do I go from here? I can't pull start since it's a hydro. How do I check compression on this engine before I spend hundreds on a pump rebuild if that is what is needed? Tractor seems to be in awfully good shape considering tach shows over 8000 hours. However tach goes to 3000 rpm with a 2700 rpm pto, so I'm not sure the tach is origional. Wheels and tires and paint are not origional. I though the late 656 diesels were governed to 2300. Any advice would be greatly appreciated!
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
