THe sleeves are worth removing, as they just push out the top with a block of wood and a 2 pound hammer. The pulley will not come off easily. if it has a set screw, it will be obvious. Most are interference pressed fit. I have seen some take 15 ton of hydraulic pressure, and very good support to get them to budge. Heat the pulley shank (not red) and it will come easier. The use of a Good bearing splitter behind the pulley, and a press is often needed. Sand the two to allow a less dramatic reinstall. (not so as to make it slip on though!) Bearing pullers with arms will break the pulley at 30% of the needed force! Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
