If you are real careful putting the seals back in it should last. Unless the bore or shaft is scored or worn too bad. From your picture I would say that you have to compress the two end plugs back into the barrel just enough to get whatever is in those rectangular holes to come out, whether it is a wire or flat plug of some kind. When you put it back together and hook the hoses up, oil pressure will push the plugs back in place. Not sure about the block on the right side, must have to unscrew off the rod to get a new seal in the end plug, unless the piston inside the barrel comes off the left end somehow. I would have to see it. Hope this helps somewhat.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
