Drain the read end remove the bolt that hold the hyd. pump plat to the rear end and pop it off , unbolt the old pump replace the o/ rings install the new gear on the new pump tighten the nut that hold the gear on clean the gasket off the plate and the rearend houseing install a couple guide studs put the new o/ ring inplace with some grease to hold it there but the gasket on the guied studs and slid the plate back on and bolt down and refill the rear end along with a new filter. done.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
