Posted by John Franklin on August 05, 2012 at 09:01:51 from (76.106.36.212):
Posted a while back about a possible dead battery. It wasn't dead. Charged it back up, hooked it up, polarized the generator, and started it up. Measured voltage across the battery. About 6.2 volts. The ammeter needle doesn't move at all. Increasing speed, decreasing speed, or shutting it off. So is my problem a voltage regulator, generator, or could it be the battery is at full charge so there is no charge going back to battery?
All connections, clean, bright, and tight.
Also, tested the circuit to make sure there wasn't a current draw after the tractor is stopped. Unhooked grounding strap, no current measured across battery circuit (measured from negative post hooked to started to grounding cable unhooked from positive terminal).
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
