Posted by John T on August 06, 2012 at 19:24:28 from (216.249.82.117):
In Reply to: Hot Coil posted by Mark W. on August 06, 2012 at 18:03:53:
Its hard to describe how "hot" but in general many get fairly "warm" but shouldnt get so hot you cant keep your hand on them. But a lot depends on how and where they are mounted due to ambient heat and heat transfer.
The pertronix switch uses a solid state device to switch coil current on and off instead of mechanical contact points opening and closing, but shouldnt drastically affect (if alls well) the coils basic current draw.
Is the coil matched to the tractor?? i.e. if its a 12 volt then is the coil a true 12 volt rated (labeled 12 volts or 12 volt not for use with ballast) coil?? Its NOT a 6 volt coil now is it?? that would get real hot. Its NOT a coil labeled "12 volts for use with ballast resistor" is it??? If so it means what it says YOU NEED A BALLAST or it will get real hot.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
