Posted by The tractor vet on August 08, 2012 at 08:55:34 from (76.212.234.198):
In Reply to: 3688 TA pressure posted by dwag on August 07, 2012 at 16:17:11:
When you replaced the spring did you check spring lenght ?? Did you replace the MCV pump ?? are you sure that you do not have a leak and loosen pressure else were . Normally i have to remove a coil or two to decrease pressure to get what i want . Normally with a new spring kit you would be at around 290-310 and depending on what tractor it is i set pressures between 235-275.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
