F 12 governor help
Posted by Craig45 on August 11, 2012 at 08:33:59 from (71.191.1.123):
Engine runs erratic and rockshaft to carb throttle plate vibrate back and fourth. This is worse as speed is increased. If I hold the shaft still with my hand the engine smooths right out. I adjusted the shaft as per paragraph 66 in the service manual but this had no effect. I removed the housing cover and there is a lot of play between the thrust bearing and governor sleeve, flyweights are real loose. Has anybody delt with this situation before? Any help would be greatly appreciated. Thanks
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
