Posted by rustred on August 11, 2012 at 20:13:13 from (184.151.222.174):
In Reply to: Good Carb Rebuilder posted by Mark W. on August 11, 2012 at 19:54:22:
well in 2 yrs. time anything can happen, sure sounds like you have a fuel restriction problem going to the carb. you may even have a bit of water in the carb bowl, or a piece of rust floating around to block the jet. have you drained the bowl? have you checked for good gas flow at line before entering carb? you dont need to rebuild the carb to make it run, you need it clean , float set and adjusted properly. i have cleaned so many carbs by just soaking them in cleaner and reassembling with the old parts and even making my own gaskts.in doing this i can spot what needs to be replaced, such as needle and seat or float and so on.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
