Re: ih 656 amp light help
Posted by Owen Aaland on August 12, 2012 at 13:03:50 from (216.47.35.23):
In Reply to: ih 656 amp light help posted by mh mo. on August 12, 2012 at 06:41:06:
This is the wiring diagram for your warning light.
http://www.tractorshed.com/gallery/community/c3719_lrg.jpg
If your wiring is good you may have an alternator that is not working properly or a bad relay in the regulator. If the alternator is working properly you should have over 6 volts on the R terminal at the alternator. That voltage from the alternator closes the relay in the regulator and turns off the indicator light. When the relay closes it also provides battery voltage to the field windings in the alternator.
If the relay does not work the power to the alternator field coils is provided through the indicator lamp and the resistor at the regulator. Since that circuit provides less than battery voltage it can keep the alternator from reaching its full output.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
