Posted by wtk on August 13, 2012 at 11:39:54 from (68.68.144.44):
I put a brass float in my Regular and set top of float to the machined line in the Bowl. The only way it will run is with the choke at half and the top fuel mixture knob screwed down tight. Should that brass float be set differant then the cork?
Maybe below the line a little.
Ran with out dripping gas. I shut it off by shutting off gas.
Turned gas on with out it running and doesn't leak or drip from vent.
Could I have a air leak between carb. and manifold?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
