Hi Steven, the PTO clutch could be stuck. Re transmission clutch slipping, the pressure plate fingers are adjustable thru the clutch inspection plate on bottom of clutch howsing. The dual stage clutch is more difficult to assemble and adjust than single clutch, see following from Bernard le mecano: Hi, you can place all the clutch and pressure plate on the shaft and bolt the engine to the rear end. If you remove the PTO clutch, make sure to align the clutch carefully in the center of the pressure plate, before replacing the bolts on the fingers, for that, remove the flywheel, place it on flat surface, put the transmission clutch, the plate, belleville spring, plate, PTO clutch, then pressure plate, belleville spring and cover. Align all of the parts, put 3, 5/16 long bolts and hand tighten to the flywheel. Secure the 3 bolts on the fingers and jam nuts, then adjust the gap. Make sure to adjust the 3 fingers at the same level. The gap for the 3 bolts is .090 inches. Remove the pressure plate, replace the flywheel on the engine crank and finish the job.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
