Posted by Bob M on August 13, 2012 at 19:51:49 from (67.240.168.11):
In Reply to: My posted by Patrick HMD on August 13, 2012 at 17:02:05:
As the others point out the rim/tire can be removed without removing the wheel. But it takes a bit of fiddling to accomplish.
Tip: If the front tires are wider than stock (like 6.50 x 16) it helps to jack the entire front end (jack from beneath the clutch housing) then remove the 3 mounting bolts from BOTH rims. By moving the now loose rims around you will have more space in which to manipulate the rim/tire and work the rim lugs around from behind the cast wheel center.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
