Posted by D Slater on August 14, 2012 at 07:53:28 from (184.15.20.202):
In Reply to: Governor on H Farmall posted by Kenneth Blackwelder on August 13, 2012 at 18:06:58:
First place to check is between the governor housing and the front cover. If someone siliconed in place of or on the gasket the oil pressure passage may be pluged. Or if someone made a gasket the slot opening may be left out from front cover plate to the governor housing oil feed hole. Next to check is recent work under the front engine cover or cam bearing recently installed. If none of the above the small metering hole may be pluged from a dirty engine. Oil pressure is not fully sent to the governor housing and idler gear through 360 degrees rotation. Think a slot in the front cam journal just sends oil pressure to the passage so many degrees a revolution. If the cam bearing is installed with holes in the correct place. I may not remember everything about the oil system but the governor is not a complete splash system. Maybe some to the drive gear and front bearing is all.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
