If you lined the clutch plate up on the flywheel. Extra clutch shaft from a salvage tractor works good. Put the transmission in neutral the PTO in gear and turn the PTO shaft when the engine gets to the splines. Dowel pin on each side of the bell housing helps keep the engine straight. Some clutch housings have a casting lip on the inside bottom part that the ring gear will catch on with dowels used though. If a problem I grind the housing enough to clear.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
