I'll share what I did with my F-12 tank. It too had 2 screws and bondo on the bottom for a repair.
I emptied the tank and removed ALL fittings, caps, etc. and I also removed the repair. I then let the tank sit in the hot sun for a few days, which "cooked" out all the fuel that was in it.
Tank was cleaned and paint/rust was removed both inside and out. Repair area was rust stabilized and then filled in with JB weld, and sanded/formed to contour. I then used an epoxy tank liner on it (following the directions). prepped, primed, and painted.
No leaks, no peeling, and no bubbles. for smaller repairs to sheet metal and gas tanks (dents). I prefer JB weld vs. bondo. It is more expensive, but I feel it is a better solution for parts that sustain lots of vibration. The only body filler product I use is spot putty to fill any tiny bubble holes in the JB weld and fine feathering. I would be surpised if the spot putty was thicker than 1/64" in any of my applications.
there are good suggestions in this thread. Use the one you are most comfortable with doing. Brazing, solder, MIG weld are all viable options as well. It all depends upon what your capabilities are and the task at hand.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
