Some things to try. Modest compression loss (rings or leaky valves) can be exaggerated at low speeds where there is time for leakage to make a difference. A check of compression on the gas start cycle will check differences between cylinders (they should be within 8 to 10 % of each other) Poor injector pattern at low flow will also produce the issue. Find the missing cylinder/s by cracking loose the injector lines at the pump when running to find the ones not firing. Then swap the injectors between those and running cylinders. If the misfire follows the injector, the injector is in need of rebuild. Pumps and timing can be a factor, but the others are more likely. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
