International 784 4x4 problem
Posted by Ih 784 on August 19, 2012 at 08:44:45 from (72.45.45.5):
I have an international 784 4x4 tractor with a zf front housing. I noticed about an inch of the axle shaft that goes into the differential on the right side was pushed out. Then I was using it and noticed the drive shaft that goes to the differential was slipping instead of spinning like it should. So I took the front axle out of the differential and 1/4 inch of the splines were wore down. So I put the shaft back in and pushed it all the way into the differential and when the wheel is turned and hits the stops it pushes the axle back out. Also I've noticed on some diagrams that on the right side there is a double universal joint and on my tractor I have a single. Also, the left side has a bigger universal joint than the right side that we're working on.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
