Re: Timing 1946 Farmall H
Posted by SadFarmall on August 20, 2012 at 02:02:54 from (121.79.12.159):
In Reply to: Timing 1946 Farmall H posted by Bob Borman on August 19, 2012 at 17:32:39:
If the tractor has magneto ignition and the timing is not too far out, you can just remove the distributor cap and gently turn the motor over until the impulse coupling trips. If the contact on the rotor is pointing to the place for Number 1 cylinder high tension lead, you are on the compression stroke for that cylinder. If not, turn the motor through another 360 degrees. For coil ignition, you can work out the compression stroke as Gene Bender has said. The method of putting your thumb over the plug hole requires extremely long arms or an assistant.
SadFarmall
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
