Re: Fuel in crankcase oil
Posted by sflem849 on August 22, 2012 at 05:30:21 from (69.197.84.39):
In Reply to: Fuel in crankcase oil posted by Janicholson on August 21, 2012 at 18:16:24:
Janicholson said: (quoted from post at 18:16:24 08/21/12) The injection pump seeal at the drive is worn. Depending on model and pump it is either real easy, or pretty easy. Make sure the engine is at TDC #1 before removal, do not turn the engine and keep the gear teeth in time. Jim
That is not a 100% of the time solution. However, if you are getting case dilution in your injection pump that is then going to your crankcase it is.
My MD problems were caused by leaking/malfunctioning injectors. Rebuilt the injectors and no more problems.
Nobody asked what tractor this was. I assume it is a gas start diesel?
This post was edited by sflem849 at 05:31:43 08/22/12.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
