Adjustable main fuel jet.
Posted by Mr. farmall on August 22, 2012 at 10:39:26 from (69.141.208.188):
I am thinking about replacing the fixed main jet in my A "s carburetor with an adjustable one. The reason for this is a I do not think the compression is high enough to properly burn the 10% ethanol in modern gas. Most of the good carburetor rebuilders recommend setting carburetors 10% richer than stock to prevent a power decrease.
Any one else install an adjustable jet to offset the "leaner " E10 gas? Is their a slightly richer fixed main jet I could install? So far I have had to set the float level a little higher than factory because the motor starves for fuel under high load with the stock float level.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
