Re: New guy with a question about SA
Posted by Jim Becker on August 26, 2012 at 10:57:19 from (173.74.120.222):
In Reply to: New guy with a question about SA posted by Jason S. on August 26, 2012 at 09:33:04:
I haven't touched those parts in a while. I had thought there were flat washers, but the parts catalog doesn't list any, so evidently not. The catalog lists lock washers for the 2 long studs at each end. The short middle stud is a special case. Do NOT put a lock washer on it. More importantly, make sure you are using the correct stud. The stud is hollow in the lower end and there is a hole in the side that meets the hole from the hollow end. This hollow stud is the oil feed to the rocker arms. Do NOT substitute a plain stud or a bolt for the hollow stud. Also, go easy tightening the middle nut. The hollow stud is weaker than a solid one and easy to twist off.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
