The wire you have running to the hot side of the coil can be there but there has to be a wire from the ignition switch to that post too. That wire is the exciter wire that when energized tells the alt to charge. It has the diode inline to prevent it from back feeding electricty and draining the battery when the engine is off. Without the diode it will backfeed enough that it willl feed the ingition system too not allowing it to shut off.
The wire on the other side of the amp meter has to feed back to the battery to charge it.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
