Re: Help! Farmall 400 12v Conversion
Posted by mkirsch on August 28, 2012 at 10:56:56 from (64.80.110.75):
In Reply to: Help! Farmall 400 12v Conversion posted by TylerFarmallH on August 27, 2012 at 19:41:07:
One terminal from the ammeter should go to the + post of the battery, or the battery connection on the starter solenoid.
The other terminal from the ammeter should connect to three things:
1. Hot to the headlight switch
2. Hot to the key switch
3. Hot to the BAT terminal on the alternator
The 400 has a twist-key-to-start setup so the key switch will have two other posts:
A. Hot to the ballast resistor
B. Start to the "S" post on the solenoid
The ballast resistor will have two connections:
I. Key switch side to diode and on to the alternator's #1 terminal
II. Open side to + post on coil, - side of coil to distributor
If it's hooked up that way and still doesn't work, check your work again because it isn't hooked up that way. Either that, or you have gremlins.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
