Posted by Bill Novak on August 29, 2012 at 19:20:18 from (50.123.215.82):
In Reply to: Re: lack of power posted by Janicholson on August 28, 2012 at 19:00:49:
Thanks Hal&Jim.The fuel appears to flow well out the vents and out the fuel line that feeds the pri filter and secondary filter.I opened the banjoe fitting that sets on the pump from the sec filter,therethe flow is less.The engine starts easy and does not stumble or miss.The three position lever in the run position is on the positive stop if you move it a little the motor sounds like it's retarded.The air flow seems good(replaced air filter)and the snout is open there is some black smoke but not bad.I put some essentialube in the fuel and will see if that helps.Bill
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
