Re: clutch installation
Posted by Janicholson on August 30, 2012 at 13:52:21 from (199.17.6.249):
In Reply to: Re: clutch installation posted by BigTone on August 30, 2012 at 04:58:43:
If the clutch alignment tool is used, it is just [placed in the spline hole and into the pilot bearing. I then release the clutch (three bolts) untill I can just move the disk with the alignment tool a tiny amount in any direction withoput it falling. I then move the disk left and right and up and down till I believe i have it centered perfectly using the tool. I then take out the bolts, and put them where they belong. Now you are assured that the disk is centered. leave the tractor in Neutral, and turn on the PTO as you put the engine in have someone rotate the PTO with a Pipe wrench to rotate the clutch shaft till the splines engage. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
