Posted by Haas on August 31, 2012 at 16:10:31 from (75.252.40.130):
In Reply to: Re: MD Mag is Dead posted by IAtractorKid on August 31, 2012 at 14:29:10:
There should be a pointer and mark (notch) on the pulley on the front of the engine. Line those up and note where the rotor is pointing and then take the mag off. When you put it back, make sure the rotor on the mag is pointing the same direction as when you took it off and you should be good to go. If your crank thing is stuck, you can turn the engine by using the belt pulley flange. Put the transmission in neutral and the pulley in gear. Put a couple of bolts in the flange and use a bar to turn the pulley flange and thus the engine. Just be sure there is no possibility the engine can start when you do this!! If you take the plugs out and put the start lever in gas position, it will be easy to turn the engine with this method.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
