I believe that is a pilot operated check valve block that helped keep the load from drifting down. Took everything out of the system except the cylinder itself... if the cylinder leaked by the piston, it would settle anyway. The way they work is when pressure is applied to one side, an internal "pilot" line opened the opposite or return side of the line. Again, if the cylinder had an internal leak, this valve didn't help that.
I know Cessna/Eaton made them at one time and many were used on loader buckets to help stop the bucket from dumping the load as it was being carried. You could find them mounted on a cross-beam behind the bucket of a loader. One of these might work if you can find one.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
