Assuming you are talking about the axle housing and the gasket is between it and the final drive case. Jack the tractor till all the weight is off of the tire on the side that is leaking. But not lifting the tire. and put safty blocking under it. Loosen the big bolts holding the housing to the final case, and split it apart about 3/8 to 1/2". Jack on the tractor until the gap is very equal all around. scrape all old gasket out of the joint. Take the new gasket, and cut the top through so it is split where it crosses the top of the axle housing. weasel the new gasket into position. Use RTV on the surfaces. especially at the split. Jim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
