I soaked the carb for 2 days, pulled it out today and did pretty much everything that was suggested here.
I used some stiff wire to poke out all the passages, followed that with spray carb cleaner in each passage followed by compressed air.
I set the float per service manual, I was very, careful and got it as close to perfect as I could. Installed everything and no dripping from the carb so the needle and seat are working correctly. Idle screw is set 1 1/2 turns from being seated.
Same old story. The idle screw can be seated or 6 turns out and it runs just the same. I even took the whole screw out and it ran, a little worse but not terribly so. It did hiss quite bit, if I put my finger over the it would change a bit.
I did a leak test, even went so far as to spray the whole thing down with either, no change what so ever.
I guess the last draw is to pull the Marvel off my BN and install it on the A, see what that does.
Just because I could I reset all the valves to make sure nothing was funky there. All the cylinders read 85 pound plus or minus a pound. I went thought the mag, new cap, point and timed it back. I also replaced all the spark plugs.
I keep coming back to the carb due to it's lack of adjustment, I guess trying another know good carb will tell me something.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
