Posted by The tractor vet on September 03, 2012 at 17:34:56 from (76.212.232.42):
In Reply to: Re: 806 pto posted by 1349 on September 03, 2012 at 17:13:41:
NOW listen to what i am telling you here.Remove the hitch support six bolt and get it out of the way , Place a bucket under the valve plug and remove the plug then put the plug back in . This way you will not loose all the oil . Remove the top nut off the valve stem and remove the top nut and Pull the stem out . Now that you have the two pieces out go to Case I H and get the PIN then you take the two halfs of the valve and install the pin, Now that you have one LONG valve remove the bottom plug and stuff the valve UP into the PTO and replace the plug and put your hitch support back on Then install a new seal and O/Ring and Dust boot . Now put the square nut back on and hook up the linkage , check the hyd. oil level and add what ever is needed . Install the special test fitting (this can be ordered from Case I H ) and hook up a gauge and run the tractor TILL the Oil is WARM. then ya you screw the valve stem up into the nut deeper with the PTO engaged and set it at the 235-245 .
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
