The bore spacing and (thus) length of crankshaft must be longer to accomodate the added bearings. Long stroke (under square) engines can (in the 1920s) when these were born) could be operated at less than 2000 and had enough crank stiffness to make it work. When we put 50% more air in the engine (and fuel) the engine makes lots more power. Compression (effective) can reach 200psi and real racing fuel is needed. Timing cannot be advanced much more than 15 degrees from TDC unless the engine speed reaches 3000 to 4000 RPM. which now again doubles the HP if the intake and exhaust valve timing allows for it (cam not stock). Rods and mains and journals designed to be robust at 55HP look like pot metal at 125. Holding together is one thing, running for hours is another. Tearing down a M is trivial, but after 5 times real expensive, and real boring. One must realize also that the trophies are 20$ items. I understand toys and have my share of non stock stuff. (most of it is non stock) but it is reliable and stronger, not a design for detonation (in the big sense) No offense to all who put big money and time into racing or Pulling, one just has to be able to afford it. Jim
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
