1. You lost the prime on your hydraulic pump. It should come back if you cycle the hydraulics several times with the fill plug removed. If that doesn't work, pressurize the block through the fill hole with an air compressor.
2. You put it back together incorrectly. How, I don't know. Could be the too-thick o-ring. Could be you put something else in turned 90 degrees, or flipped over, or, or, or...
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
