Points ground the coil. When the points are closed, there should be no detectable voltage at the distributor side of the coil from the terminal to ground. When the points are open, with a good condenser, the voltage at the distributor side of the coil should be full battery voltage. The 2 to 3 ohms of resistance through the coil do not drop the voltage on an open circuit (like it is) enough to change the voltage reading on a Multi meter. So basically you cant measure the voltage drop and make sense out of it. In simple terms it is just like measuring from the block to the key with the points closed, and the low internal resistance allows a sensitive meter to read battery voltage right through the unloaded coil when the points are open.
When the points are open the coil should read between 2 and 3 ohms measured across the little terminals Jim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
