Posted by The tractor vet on September 08, 2012 at 14:42:25 from (76.212.230.88):
In Reply to: 806 PTO fixed posted by 1349 on September 08, 2012 at 14:19:12:
IF you are having trouble getting the pressure then do this. Loosen the two 1/2 inch bolts that hold the linkage bracket to the PTO unit and pry up the bracket and hold it up while someone tightens it up . This should get you about 40 lbs more . Ya don't want to run it that low as you will walk thru the clutches. under load . If you egg shape the holes in the mounting bracket a little on the bottom side it will help . Due to age and ware your not getting the LIFT on the valve .
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
