Dangit! what did I screw up
Posted by Paul Shuler on September 10, 2012 at 18:18:07 from (69.71.1.1):
Worked a 16 hr shift last night, slept for 4 hrs then worked
another 8. Came home and thought it would be a good idea to
work on my tractor. Man am I dumb. I was way too tired. I
bought a new 6 volt battery to put in it and it wouldn"t start after
wards. Looked and was out of gas. Put 5 gal in and still wouldn"t
start. Began chasing fuel lines looking for a problem. Tried it
again and it started but died right quick. Then I started looking
at all I had done and about messed my pants when I saw that I
had hooked the battery up backwards. Neg ground! Uuuugh. I
unhooked it and turned it around and put the charger on it and it
seems to be taking a charge. I have not tried to start the tractor.
Have I screwed anything up? I am so dang mad at myself. To top
it off I turned the drain plug on the bottom of the carb the wrong
way to loosen it and now it wont tighten up. It is not leaking but
it is just finger tight. I get so angry when I do stuff like that.
When I have a little time I try and get too much stuff done and
make mistakes. Maybe someday I will learn to be more patient.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
