Posted by todd hamilton on September 14, 2012 at 12:38:59 from (71.88.209.5):
In Reply to: How do you time a M? posted by BigTone on September 14, 2012 at 09:00:08:
It's pretty simple. By rotating the distributor you are advancing or retarding the spark. You want to use a timing light as specified by the instructions for your engine so the plug fires at the top of the power stroke at maximum compression. You can get it close by timing it with the engine off, with spark pluga out hook up the plug for #1 and hold your thumb over the plug hole. Have a helper crank the engine. The plug should fire when you feel maximum pressure against your thumb. That's the rough setting, fine tune it with the timing light aimed at the pointer on the crank pulley. Mark the pointer with white paint, it will be easier to see. Listen to the engine, it will lean out an run sweet when you hit the right spot.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
