Re: How do you time a M?
Posted by glennster on September 14, 2012 at 14:37:59 from (75.57.143.173):
In Reply to: How do you time a M? posted by BigTone on September 14, 2012 at 09:00:08:
like janicholson said, static time the engine, unless your timing light has an advance function, you wont time it correctly with a light. look for two marks close together on the crankshaft pulley. the first mark in the direction of rotation is tdc. that is where you want to be for a distributor ignition. there should be a single mark a ways around the pulley. if you happen to line that up with the timing pointer, then crawl under the tractor and look up in the hole at the bottom of the bell housing, you will see the grease zerk in the fly wheel to lube the pilot bearing. pretty tricky eh?
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
