Posted by D Slater on September 16, 2012 at 07:43:26 from (184.15.50.155):
In Reply to: M Belly Pumo posted by John M on September 16, 2012 at 05:57:44:
Unless the control arm is not moving the shaft going into the liftall housing its going to have to come out. Once the back plate is removed from the reservoir its pretty simple to see and figure out how the linkage works. For some reason the check ball is not being pushed off the seat to let the fluid back, unless the plunger that moves to pump or bypass is staying in the pump position. If its just a problem with the one ball check he may get lucky and move the line and operate it. If pressure line is connected to the right side opening, move it to the left rear or vice versa. Those openings use a different check ball to let the pressure back. If the internal linkage is apart or broke that works them it won't work though.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
