Re: FARMALL H CARB ADJUSTMENTS??
Posted by T_Bone on October 14, 2000 at 02:27:42 from (207.254.53.37):
In Reply to: FARMALL H CARB ADJUSTMENTS?? posted by LOU on October 13, 2000 at 18:14:55:
Hi Lou, I've never worked on a H, but lookin at the parts book: 1: On the upper main body on the left side is the idle rpm adjustment. Adjust for proper rpm at idle. 2: On the lower left side body, is the idle inrichment screw. Turn for best idle, but if turn all the way in and it makes no difference then the idle circuit is still plugged. Reclean. A preset is 1 turn out from seat. 3: On the lower body bottom a screw running from right to left at a 45 degree angle is the high rpm fule mixture screw. Run engine at 1500rpm and set for best rpm without missing. A preset is usually 1-1/2 turns out from seat. A Rich setting is better. I usually turn to best lean run, then turn rich 1/4 turn. Lean is screw in, rich is out. 4: On the upper body rigth side next too the fuel inlet there is a idle passage plug. This should be screwed all the way in. But if idle circuit is running ruff, then remove and clean passage with Chemtron Berriman B-12. 5: Inside of lower bowel left side is a idle jet metering screw, so that should be cleaned upon rebuild. 6: On lower right side is a pin, ball,and spring used to set tension on the choke butterfly and used as a dent setup to hold the choke open. Thats all I can see in the diagram and should be a complete adjustment. Let me know if you need more help! T_Bone
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
