well i would take a look at the gov. and see how sloppy the gov. spring fits into the levers-arm inside the Gov.There should be no slop as there should be bushings where the spring goes thru the arms. if they are not there then you can make up either bronze or steel bushings and press them in . IF you make them you must chamfer both sides of the hole where the spring fits thru so it does not bind. Then look and repair fix any sloppy linkage from the throttle lever down to the gov. I think this is your problem .
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
