If you have the factory pipes with rubber hose the suction is just a short rubber hose with clamps. Pressure hose came made on the smallest diameter steel pipe with a fitting on the other end that screwed on the pump hydraulic manifold. Also you could have rubber added to what came as all steel lines.
If you have the factory lines like in the picture, maybe the easy way is to cut the pipe just behind the rubber. Then get a compression fitting from a hydraulic supply and hydraulic hose with a end to screw on hydraulic manifold and the compression fitting. Second picturing is of the fitting on a gas tractor line so you can see what it looks like. Rubber is 3/4 inch cut to length. Take the old fitting, hydraulic shop will know what ends to use on the new hose.
This post was edited by D Slater at 17:49:38 09/20/12.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
