Re: 300 Farmall float adjustment, long post
Posted by CNKS on September 22, 2012 at 17:48:48 from (216.144.104.128):
In Reply to: Re: 300 Farmall float adjustment, long post posted by rustyfarmall on September 22, 2012 at 15:22:50:
Rebuilding has nothing to do with adjusting. The directions in the Operators manuals differ between the H/Super H, and M/Super M. It is in the manuals in black and white. Perhaps you don't have the Super manuals, I see no other reason for you to disagree. If you use the 3 turns out for the initial setting the H and M will probably run ok, but the guy getting your carbs should adjust with the in until rough out until smooth to assure a lean mixture. The Super H/M-up will not run properly if adjusted that way, at least not with any load. I have a 460 that I tried with 4 turns out, it lost power so I use 5 turns. It runs a little rich possibly due to some other problem, but more likely because it doesn't get run enough.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
