Fix what you have. 340 and 504 have the same size transmission case that can be used with center housing internal hydrualics. But there's so many different gear ratios used along with differentials, bull pinion gears, bull gears and axles that things get complicated. There is a lot of parts that can be switched between rears, but takes study of parts to do it. If the 460 doesn't have a CC suffix on the serial # plate the 300 and 350 farmall will have 3rd gears you can use to replace the 460 with. If it does have the CC I can't remember what other gears are the same without looking it up. If repacing the 3rd gear on the counter shaft along with the 2nd and third slider gear you can install the gears even if its the different third gear ratio. May not want to change your ground speed though. 460 third with the CC suffix is a slower ground speed than ones without CC.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
