Re: IH 2001 loader
Posted by Red Mercury on September 23, 2012 at 15:49:56 from (204.112.37.125):
In Reply to: IH 2001 loader posted by oldtanker on September 22, 2012 at 18:38:02:
I just had the bucket cylinder fixed on my 2001 loader. I had purchased the seals & O-rings about 15 years ago and had them on hand. At that time a kit was not available but they could be purchased individually from IH. The shaft on mine was also damaged and needed to be replaced. I took my seals to a good hydraulic shop and they were able to supply a new shaft for the cylinder. The shaft dimensions are fairly common so they are not hard to find. The only problem was that the yoke also go replaced since the shaft had a different thread. The original yoke pin is not long enough fo rthe new yoke. The original pin was made from a very hard steel and the new one is just a mild steel so I hope it doesn"t wear too much. After all parts & labour it was expensive, almost $400. I can provide the IH part numbers for the seals if you want to get them. I think a good hydraulice shop could also supply them.
If I did it again, I would take the cylinder to a hydraulic shop that does machine shop work and ask them to make a shaft with the correct thread so the original yoke and pin could be used. I am fussy, I like things to be done as original as possible.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
